Ok, I have an hour long mp2 file that I captured from TV yesterday. I want to use TMPGEnc to cut the commercials out and then put it to DVD. However, when I cut it, i get a total out of sync problem. The sound seems to be right where it should be, but the video is about a minute or two past where i wanted the vid file to start.
I tried to de-multiplex it to extract the audio from the video. I wanted to cut the audio and video separately and then combine them later. The audio was fine and I was able to cut the right part I wanted with GoldWav. But the video file was reduced to 30 minutes!! I totally gave up, I need help.
Results 1 to 1 of 1
TMPGenc Authoring Works 4 sync problem
By deadmort in forum EditingReplies: 2Last Post: 1st Nov 2011, 06:41 -
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 10:27 -
Virtualdub causes audio sync issues after cutting/saving
By Mr_Lyle in forum EditingReplies: 1Last Post: 23rd Apr 2008, 15:55 -
cutting a large WMV - audo/video sync is off
By djbryson in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
