I have a svcd file (that's what it says, but I can't open in Virtual dub to see exactly what it is) and I was wondeing if I can change the aspect ratio without having to re-encode. Or if there is soething I don't know please tell me.
Thank you all!!
Go to the Tools section at left and get Virtual Dub MPEG-2 AC3 mod. It will open your video.
Hello. -
A few things you should know...
SVCD doesn't support a 16:9 ratio.
You can put a 16:9 ratio on an mpeg without re-encoding, but unless you change the resolution of the SVCD to the proper height width, then it gains you nothing
In order to change the resolution of your SVCD, you must re-encode.
If your SVCD is letterboxed, then you can clip off the letterboxing, resizing your MPEG to a 16:9 resolution, while still keeping the 4:3 aspect ratio on the MPEG. Your resulting SVCD would only look 'right' on a widescreen television though. To do so, you have to find the aspect ratio of your SVCD without it's letterboxing (if any).
If your SVCD has an image aspect ratio of 1.85:1, simple removing all letterboxing, and resize it to 480x480.
If your SVCD has an image aspect ratio of 2.35:1, resize the image area only (image area being that part of the movie that does NOT include letterboxing), to 480x360, and add 120 pixels of letterboxing (60 top, 60 bottom).
If your SVCD has an image aspect ratio of 4:3, then you would have to hack away large portions of your video's top and bottom area to change the aspect ratio (not suggested).Impossible to see the future is. The Dark Side clouds everything...
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 04:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
