I downloaded some movies that are .avi's and went to convert some of them to svcd, but I get an error when importing that says, cannot open or unsupported. What could be the problem? How could I check to see exactly what format they are besides the file extension? Any help would be appreciated.
Results 1 to 9 of 9
Go to the tools section and download avicodec. Load your avi in it and it will tell you what kind of film it is and if you have the proper codecs installed.
gspot will also tell you what AVI file you have - download the codec you need
Panasonic DMR-ES45VS, keep those discs a burnin' -
I downloaded and ran avicodec, but every time I try to import the movie it crashes it out and it asks if I would like to send error message to Microsoft. Could the files just simply be corrupt? They came from share reactor. There are probably 50% of these files doing this. The others can be imported into TMPG fine.
You did not try to adjust the Direct Show priorities, did you?
Hello. -
Yes, I made the direct show the top priority. After doing that, instead of getting the error message it justs crashes the program.
Okay. After you select Video-->Scan video stream for errors try to frameserve into TMPGEnc from Virtual Dub.
Hello. -
You said: Scan video stream for errors try to frameserve into TMPGEnc from Virtual Dub.
How do I do that in avicodec? I may need a more thorough explanation. I am fairly new at all of this. Your help is greatly appreciated.
Ripping CD (Enhanced Video) Unknown Format
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 30th Jan 2011, 20:20 -
Adventures in importing... unknown format in .mov wrapper
By vidhelp22 in forum Video ConversionReplies: 2Last Post: 19th Oct 2010, 23:30 -
mp4 "unknown format"
By daresound in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2010, 22:55 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 09:10 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 12:14
