I want to watch my DIVX discs on my PS2 but dont know how to do it with a mac. Can anybody help? I have swap magic but cant find a boot disk.
Results 1 to 10 of 10
I think you might need something like QCast Tuner to play Divx on your PS2. It's $50 and available here: http://www.broadq.com/qcasttuner/. You also need the PS2 network adapter. I don't know about CDs and DVDs with Divx files.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Like Wiseweasle says Q-cast tuner is great for playing Divx movies without going through a lot of hassle
There is also a ps2reality Divx player
But before you can use this you have to have your ps2 modfied by modchip or use a boot disk like the swap magic or gameshark with a no solder/flip-top type swap trick -
I've had a look at ps2reality but I thought it was PC only? How do I get it to work on a Mac?
once you unrar the zip file then you burn the .bin file using toast under the disk image setting.Originally Posted by corgi74
The program is for your ps2 you insert the disk to boot the ps2reality program then insert you divx movie into your ps2
Tried that but so far I've done 6 coasters. I downloaded 1.28e and stuffit unzipped it but the rar is corrupt I think. help!!!
Did you burn the bin using the disk image option in toast?Originally Posted by corgi74
If that doesnt work try burn the .bin and .cue file using firestarter
Also what chip or swap method are you using (fliptop/slide-card/no solder) do you use?
With swap magic
You just boot up your swap magic cd then when it says start then do your knifetrick/swap method like a regular ps2 cd backup -
Where are you guys getting this file? I've been looking for it for awhile, but it's hard to find. Can you post a link to it perhaps...I've got a modchip and would really like to start playing Divx movies on ma PS2!
TIA
-kami -
Did it exactly as you said but no luck, Only got a bin file and I think that it was dodgy
Hey
Just to let everyone know. I got the Divx Player going on my PS2. Mine's modded, so that would make a big difference. Actually, the copy of the player that I got came with an ISO disk image that basically had the perfect layout for the CD. So i just opened it up in toast and burned it. The only thing i can't get to work is burning an AVI on a cd. It's not just a matter of making a 9660 XA CD and throwing the file onto it. There's something you've got to get right, because when i load the divx player, you take the player cd out and throw a CD with the AVI into the PS2. When the divx player looks at the CD it doesnt list the AVI i've burnt onto it.
I named the CD "MATRIX_CD" and just threw "MATRIX.AVI" into the root directory. Does anything about that seem flaky? I burned it as a 9660 CD XA, just like any other PS2 disc.
-kami
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 20:47 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 23:36 -
Capturing PS2 Footage
By -ODeN- in forum Capturing and VCRReplies: 3Last Post: 6th Jan 2009, 16:21 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 12:31
