anyone got any ideas how to convert flash animations to mpg or avi ?
Yes! I have successfully done it using RAD Tools.
You can use it to convert your .SWF file to an .AVI , then reconvert to MPEG. It is freeware, and can be found here:
http://www.radgametools.com/down/bink/radtools.exe
its pretty straightforward to use it.
it makes for cool VCD\SVCD intros -
Did you get RAD Video Tools to convert SWF -> AVI *with sound*? Or it does Video only?
Now that you mention it - i think i just converted the video portion with RAD and used TOTAL RECORDER for the audio...then encoded/muxed in TMPEG.
You may have to try a few trick to sync sound, it depends on your source i guess. TMPEG is pretty good about changing framerates and keeping up sync. I havent had that problem though.
<font size=-1>[ This Message was edited by: mole on 2001-09-28 16:58:07 ]</font> -
Here's the best method:
1. Create your movie in flash
2. Go to File>Export Movie
3. Under save as type choose Windows Avi
4. Convert the avi to mpeg in TMPGEnc
I hope that was of help to you,
Dhruv
I only dream in black & white...
MSN: paschendale@gmail.com -
removed converts without losing audio and video.Did you get RAD Video Tools to convert SWF -> AVI *with sound*? Or it does Video only?
How to convert a Flash video (*.SWF) to a Movie (*.AVI)
By potatosalad in forum User guidesReplies: 27Last Post: 3rd Jun 2015, 10:02 -
How to convert .flv (flash video) to .avi or .mpg
By hitrec in forum User guidesReplies: 181Last Post: 17th Apr 2010, 17:14 -
scr to swf or avi or mpg
By faithcopeland in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2008, 02:05 -
SWF file re Flash
By rotuts in forum MacReplies: 4Last Post: 4th Mar 2008, 13:46 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 15:41
