I burned a SVCD in nero enterprise edition. Burn went fine, but when I went to play in DVD player it played fine for about 30 minutes, then just locked up and glitched and flashed green back and forth in the video. Any help would be appreciated.
Results 1 to 9 of 9
Try burning again at a slower speed.
Not any faster than about 18-24x
Best results at 8x for me.
Not sure why it works that way but it does.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
I burned at 16X, but will try 8X as you suggest. Will post results...Thanks...
Originally Posted by SVCDummy"Art is making something out of nothing and selling it." - Frank Zappa
i've personally recommended burning no faster than 4X...as faster burning will exacerbate any error....
not sure about the technical side...as in theory burning speed shouldn't matter very much....but if i remember correctly from awhile ago, there could be some reasons why burning may cause an effect...again, only from memory and not sure exactly how accurate:
1) slower burns make deeper grooves in the dye??? may improve readability.
2) slower burns gives the dye longer time to dry after being burned..so the edges of the pits are straighter and more defined....i guess if burning at max speed, the dye may not have enough time to completely dry, so the edges of the pits might be a little big jagged. -
Thanks Poopyhead, being an engineer I can appreciate and thoroughly understand your explanation of burning and the way the speed can affect it. Thanks. I learned something today...and everyday.
yo i have the same problem and even if i burn at a slower speed 4x it still happens
Originally Posted by VancityG
bad rip
bad burn
bad media
i've also experienced similar glitches as well. however, if i just reburn the exact the same .mpg on another CD-R, even from the same batch, the problem usually goes away. seems to be a random fluke.
How To Troubleshoot .flv files?
By abrogard in forum Video ConversionReplies: 1Last Post: 30th Jan 2012, 03:30 -
Honestech TVR Troubleshoot
By alimech in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2011, 22:56 -
Problem after initial boot up. Help me Troubleshoot.
By hellfire45 in forum ComputerReplies: 4Last Post: 25th Sep 2010, 17:11 -
Please help me troubleshoot a skipping problem with Pioneer DV-48AV
By arkoenig in forum Newbie / General discussionsReplies: 9Last Post: 6th Jan 2010, 09:32 -
vob to avi troubleshoot
By thecos in forum ffmpegX general discussionReplies: 5Last Post: 25th Jan 2009, 11:54
