I simply need to capture in AVI uncompressed, 320x240 ...
I'm currently using an ATI all in wonder but the quality isn't that good...the avi's are kind of blurry and darker than the original DVD's I'm capturing...
So what is the best card to capture in AVI uncompressed, 320x240, and which offers lots of options to adjust the image quality...
First of all, the image is blurry because you are capturing at 320x240 and you can adjust the colours so that they aren't as dark. I use an ATI AIW also and have had no probs. Try capturing in virtualdub if you aren't using that.
you can't adjust the colors when capturing in AVI uncompressed...and the blurry image isn't normal either...320x240 is standard resolutionOriginally Posted by pixel
Does everything look bad when you just view TV? Can't you adjust the colors then?
I have a cheap Avermedia ($30) Capture card. I use the sourceforge drivers. (Not the ones from Aver). And I use VirtualVCR to do my caps.
I'm not sure if it's the drivers, or the app, but I can definately adjust the colors before I capture, and even if I capture uncompressed.
As far as blurry goes, old card?
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
