I'm currently using HJ-Split to join files I captured with a Dazzle DVC150 using the DVXCEL test utility. Since the max file capture size is 2032Gb, I often end up with 2 files (both .mpg) and have to join the 2 files.
The problem is, there is a small but noticable stutter in the video when watching the play back of the burned DVD on the topset DVD player at the point at which the join was made. Is there any way to correct this? Is there another joiner type software that will get the job done in the same manner as the HJ-Split without the hiccup?
I realize this can be done with an editing software (ex. Ulead VS7) but I don't want to have to render the footage since it's already in mpg format.
Thanks,
ChachiFace
First few seconds of media files stutter in VLC
By A Traveller in forum Software PlayingReplies: 2Last Post: 15th Sep 2011, 14:18 -
Converted Files To DVD Format Stutter ?!?
By Umbrella420 in forum Blu-ray RippingReplies: 0Last Post: 7th Jun 2010, 20:28 -
Joining mpg files from VOB2MPGPRO
By Mudmover in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 2nd Jun 2009, 07:06 -
Xvid files stutter now, used to work fine
By Caledor in forum Software PlayingReplies: 7Last Post: 30th Mar 2009, 15:04 -
My MPEG-2 Files Have a Stutter
By marotti in forum Video ConversionReplies: 6Last Post: 24th Nov 2007, 20:23
