    Jan 2003
    Canada
    have solved my prob. for frameserving but now i got a other error.
    i have tried many differents files and always same prob.
    illegal floating error ??????6
    any idea to solved that ???
    vdub with tmpgenc error in tmpgenc when i try to start encode
    thanks to all , great board!!
    Apr 2002
    The State of Frustration
    What program?
    Hello.
    Jan 2003
    Canada
    sorry :P
    vdub frameserve with tmpgenc.
    error in tmpgenc.
    Apr 2002
    Hello.
    Jan 2003
    Canada
    thanks for your patience!!
    will try that
  6. ive had that problem in the past with TMPGEnc. for me the reason why it did this is b/c when i was encoding a file i was opening many different programs and running different programs that my cpu couldnt handle mulitple programs at the same time. so i think that my TMPGEnc couldnt compete for the necessary power and ram that my other programs needed as well. and the main reason why i got that floating error is b/c when i used to download movies, sometimes there would be a frame or frames that got missed up either in the conversion to divx or downloading. whatever the case may be there would be a frame or in some cases many frames messed up. so TMPGEnc would encode up to that point and would give me that error message. so what i would do is stop the encode before that bad frame and begin the 2nd encode past that bad frame or frames. and then join them using one of the many tools here in this site. i hope this gives u an insight as to what and why it does this
