Hello,
I need your help.
I'm looking for a program which can convert files in ASF format to MPG. I've tried VirtualDub but it's unable to open ASF files because of Microsoft's copyrights or something, I've also tried TMPGEnc, this program has worked fine for me in the past but now when I'm trying to convert I get only the sound and gray screen.. It's important, please help !
Danny
Results 1 to 10 of 10
What do you mean? What happened when you tried to repair the file with ASFTools?
Hello. -
I've tried to use ViritualDub's old version, it opens the file but still not con verting. Any other way to do this conversion?
Information has to flow both ways. Two people have told you adjust the Direct Show priority in TMPGEnc, but you have not responded to whether or not you did and what happened.
Hello. -
1.3c doesn't work with WMV 8/9 files.
Go to digital-digest.com and look under ASF. There's a reall good tool for converting ASF/WMV to AVI. It deals with the variable framerate issue pretty well, but sound can be tricky. When done you will have an AVI with the M$ codecs, from there you can convert it in TMPG. Haven't found one yet I couldn't convert! (WMP doesn't like the resulting AVI....use something else to view them).To Be, Or, Not To Be, That, Is The Gazorgan Plan
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
