    I capture video from my minidv to my computer using mediastudio. Is there a utility that can tell me if this video is RGB or YUV. I have always thought that my captured video would be yuv. When I edit my video in mediastudio and go to save the avi file I only have RGB output as my only option.
  2. 1. Get the latest version of avisynth.
    2. Create a text file named something like myFile.avs.
    3. Paste the following script into the avs file.
    AviSource("C:\filename.avi").Info
    # results in a video with information in the left corner:
    4. Open the avs file in mediastudio. (If you can't, use virtualdub).
    5. You'll get the following info kind of info:
    ColorSpace: YV12
    Width 480, Height 576
    fps: 25
    fieldbased video: no
    parity: parity unknown
    video pitch: 960 bytes
    has audio: yes
    audio channels: 6
    sample type: integer 16 bit
    samples per second: 44100[/code]
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    DV is YUV always (minidv that is)
    I used that avisynth tool and it shows up as yuy2. Is this the same as yuv. I still dont know why when I go to create an avi file from my edited avi file it says under data type the only option is 24 bit RGB. Does this make sense.
  5. Here is a link about color spaces :
    http://www.video-demystified.com/mm/tutor/ch03.pdf
    I have no idea what I am talking about, but here is a shot. YUV is a general reference to a color space, like RGB. YUV2 is a reference to a 4:2:2 sampling of the chroma for a YUV color space. Kinda like RGB32 probably refers to using 32bits to represent the range of red green and blue values.
    On your origional question, do you need YUV format? I not sure if conversion looses info. Maybe you want to know that. I don't use mediastudio, but maybe if you clearified your question someone could help.
    Appearently the DV in is YUV 4:2:2.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    PAL DV is 4:2:2 , NTSC DV is 4:1:1
    another reason why it is better to shoot in PAL if possable ..
  7. I found this to be an area where I just use the settings and don't really understand. So I did some reading.
    It appears to me:
    1) yuv is the color space
    2) yuy2 is the fourcc which describes how the video datastream is formatted. In this case it is a yuv 4:2:2 stream.
    Here is a great link for fourcc info: http://www.fourcc.org/
    3) PAL DV is YUV 4:2:0. NTSC DV is YUV 4:1:1
    4) 4:1:1 appears to "hold up" better http://www.adamwilt.com/DV-FAQ-tech.html#colorSampling for editing.
    5) Big guess on my part: DV is upsampled to 4:2:2 when you edit. Hence the 4:2:0 or 4:2:1 is converted to 4:2:2 by interpolation or doubling.
    6) Conversion from YUV to RGB and back does degrade the video.
    This is just my very unknowledgable take on an unreliable source of information. The internet.
    I think this is a fault of mediastudio. In options it only gives data type output options as RGB. Of course I would not want my yuy2 to be converted to rgb and mediastudio does not actually convert to rgb but keeps it in yuy2 as verified by avisynth. There are a few thing in mediastudio like this including the output field order options. My dv is kept in bottom field first no matter what output options I choose. This I think is ok because I would not want mediastudio changing my field orders anyways.
