I've been having some problems with tmpgenc 2.5 plus crashing. I T happens randomly in different times of each encoding of mpeg2. I uninstalled and reinstalled didnt help . If anyone can help i would appreciate it.![]()
Results 1 to 12 of 12
No matter which file, or a file in particular?
Hello. -
It seems to do it on all files. all different spots of the movie each tike i try.
I'm using 2.5 I don't know if it the knew version or not. When it crashes it includes different files in the report every time and it reports that the program encountered a problem and must shut down. It encoded a movie once after i reinstalled it the first time but now it always crashes even if reinstalled.
Look in the Help-->About menu. Then go to the web site and download the newest version. I remember unexplained crashes in the program some time ago, but they mysteriously vanished when I upgraded.
Hello. -
I tried to download the new version but when i try to use it it says my trial period is up.
I was wrong I think it is bad frames. I've tried to use some guides on fixing bad frames but the movie I'm having problems with crashes vdub mp-3 freeze also. can you help? Is this avi trash?
AVI trash? Do you say that its avi files you are having problems with? If you said that at once i could have told you that i had the same problem with AVI files using DivX3. Converting to DivX4 solved the problem for me.
I think so. If vdub crashes then the file has some serious problems. You can try editting the video manually to get rid of the bad frames but it will be a bit of trial and error and hopefully it's not too bad. Check the "Edit" section for editting with Vdub.Originally Posted by patterson"Art is making something out of nothing and selling it." - Frank Zappa
Thanx for everyones advice I think I will try to get another copy of this movie and start over
Remember that AVI files need to be TYPE-2 for TMPGEnc to process it.
Type-1 AVI files will cause random point crashes. Also make sure your hard drive is healthy (no FAT problems or corruption).
I've had success with Type-1, but I have to make internal adjustments in TMPGEnc
system crashing
By alintatoc in forum Newbie / General discussionsReplies: 11Last Post: 6th Apr 2009, 09:03 -
Staxrip keeps crashing on me
By doggyjumper in forum Video ConversionReplies: 2Last Post: 4th Aug 2008, 19:45 -
Powerdvd keeps on crashing...
By uehara in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2008, 20:58 -
ALLtoAVI keeps crashing. Does anybody know...?
By hellfire45 in forum Video ConversionReplies: 5Last Post: 20th Feb 2008, 15:01 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 09:57
