Just took an avi movie and ripped the sound using vdub. Try to convert it using tmpge halfway though the screen goes black but still have audio.
I know the avi is ok because i can watch it all the way through with media player.
Also i keep getting write errors when i try to encode to mpeg2.
Totally stuck and donk know what to do!
HELP
Spence.
Not a guarantee of perfection by any means. Scan the video for errors with virtualdub.Originally Posted by Spence
I was having the exact same problem with a downloaded AVI file.
I started by trying to convert to VCD-MPEG-1 with TMPGEnc using the downloaded file for both audio and video. It converted fine except the audio was way out of sync by the end.
So I ripped audio to wav using Virtual Dub, loaded TMPGEnc with video from the original file and using the wav file for audio. About 20% of the way in the video went blank, but the audio continued to encode.
The solution for me was to follow the instructions regarding the DirectShow File Reader I found here:
https://www.videohelp.com/tmpgenc.htm#problems
Look at the 8th problem/solution and give it a try.
Best,
Tim
Virtualdubmod errors?
By mrjust in forum Newbie / General discussionsReplies: 7Last Post: 14th Mar 2010, 18:01 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
FAVC errors
By thai1 in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2008, 13:39 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
