Is there any way I can record in 352x576 PAL in powervcr
thanks
Yep. Hack the registry.
Add "352 x 576" <- note the spaces.
My new site, when finished, lordsmurf.com, will have this and several other reg hacks for PowerVCR well covered.
Lord Smurf.
Please could you go into a little bit more detail
I try and avoid the registry if i can
Don`t make me angry...you wouldnt like me when Im angry -
while youre here lord smurf another question please
In your guide you say to capture interlaced.
how do i know if i am doing this in Powervcr
thanks
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 05:30 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
