can any one please instruct me in a step-by-step process how to make dvds that are compatible with ps2. i know some people from this forum have done it because another post i read prior to posting about how the screen rolled or something.
Also, the dvds i have made have ben jerky on a dvd player we have, yes we have checked it against the supported -players list. could be the dvd-rs we use, i suppose.
Ireally do need to learn how to do them 4 ps2, pleae help me. I am fairly new to dvd-rs, be gentle.
Results 1 to 10 of 10
I assume you are talking about film rather than game if so you may have answered own question I have tried various discs and found some work "traxdata datawritered some dont work "datawrite yellow 1X" trial and error basically I usually use ic7 to shrink and burn
Ive made lots of DVDs that play ok on PS2. I use DVD decrypter/Nero/DVD2One n use mainly Datawrite Yellows n they r ok on a PS2. It can be a bit picky about certain types of media though.
I use Accus on a Sony 500 & these work great. Of course, sony also makes ps2's so great match. try writing at 1x.
I beleive there are now 7(?) versions of the PS2. One of my friends has a 2nd generation model that wont play anything, while my roommates (6th gen) will play the same discs. The newer the system is the better your odds.
I use unbranded DVD-R media that work fine on my ps2 and are written at 4x. I have one of the newest versions of the ps2 that supports DVD-R though.
I have had the same problem with jerkiness you talked about with your other dvd player and i think it seems to either be a problem with the "insert I picture" setting in TMPGEnc or transcoding closed GOP's. I have managed to overcome this problem but if someone could enlighten me to the actual fault for this i would be very grateful.
'Pixel': How did you manage to overcome the Jerkiness?
I don't know if it happens when you transcode from DVD or from when you capture. I got rid of it by capturing in mpeg2 and capturing in only i-frames and then in TMPGEnc i re-encoded with closed GOP's.
This seemed to solve the problem.
BTW: The jerkiness i got was on my ps2 only and I use Lordsmurf's capture guide:
http://www.lordsmurf.com -
Sorry, forget my last post.
I got your problem mixed up with another problem I had been having where at the beginning the movie stopped and started and stopped and started for a minute or so and played fine after that. I think I have the right answer below.
There is 2 possible reasons for your problem so I will post the answer to both.
#1. Swapped frames. (Movie plays fine on PC, but is not displayed properly on TV)
Your capture card (especially if it is ATI) may need to have the frames of the video swapped after it has been captured. To do this use TMPGEnc, and in the source settings choose "Interlace" and "Field Order A".
If that does not work this may solve it:
#2. Short GOPs (Picture is slightly jerky at regular intervals on your PC and TV)
You are using short GOP's which can cause jerkiness, especially at high motion. Try using this bitrate and GOP calc:
http://dvd-hq.info/Calculator.html#Calculator
I hope one of these solves your problem.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
