I've used TMPGEnc to encode captured files to be burnt onto a DVD, but I have been capturing some cartoons and tv episodes that I would like to simply keep on my pc and not burn. One of the programs I have been capturing is a cartoon w/ length 11 minutes. When I encode to SVCD format, the size goes down to about 224 MB--but the versions that I have downloaded from the web are all between 60 MB and 100 MB. Can someone PLEASE tell me how to encode my captured version to be this small? They are all AVI files after encoding. Thanks so much for your time and help.
From what I can tell, you want the end result to be a DivX .avi file. As far as bitrates go, follow a guide to convert to DivX w/ MP3 audio and use 192kbps audio and 675-750kbps video.
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 08:49 -
Can I store captured video on a separate hard drive and still use FCP?
By birdfeeder in forum MacReplies: 2Last Post: 2nd May 2011, 00:33 -
next to the 8mm tape whats the best way to store "raw" captured f
By st711 in forum MediaReplies: 2Last Post: 25th Dec 2009, 23:58 -
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
Fastest from captured video to dvd?
By larrym in forum Newbie / General discussionsReplies: 35Last Post: 14th Jul 2008, 08:03
