I am trying to process a DVD ripped with DVDBackup to DIVX. I would like to put the whole thing on to one CD but that may be asking for too much give quality wise. I know there are 4 Titles; the first title is a black box.
I processed Title 2 with the following settings:
1213 Kbit/s
Ratio 2.35:1
Framerate "NTSC Film"
I get VERY choppy video with of block artifacts. I am using mencoder. I tried using the ffmpegx encoder but it says that the VIDEO_TS folder is the "wrong format".
I used the "DVD to Divx" guide from the web site to do it.
One other question: the guide says that I need to hit the 'Calc Time' button. How does one discern the time of a Title within the DVD?
Let me know if any of these questions need to be clarified.![]()
Flaffer
www.imdb.com
look up the movie, it will give you the run time of the video.
or its on the back of the dvd case.
Thanks,
Flaffer
generikGuest
Here is my experience with dvd's. I first use dvd backup to get rid of the codes. then dvd2one to get rid of all the stuff you don't need. Plus dvd to one will get the movie titles out right. Then you will need the FFmpegx patch from www.versiontracker.com or macupdate to allow ffmpegX to convert mpeg2 vop files. Then simple get ffmpegx working on the 4 vop files. The last is usually the titles.
It is best to use the vop files on your HD rather than DVD player cause it takes less time and saves you dvd player from constantly starting and stopping (wear and tear).
After you can use 'ffmpegX' or 'split me' to join the converted vop - divx files.
FFmpegX MP4 to DivX/Xvid No Audio
By TDC_01 in forum ffmpegX general discussionReplies: 4Last Post: 21st Nov 2009, 19:49 -
DivX created by ffmpegX doesn't work on player?
By ambrosechapel in forum ffmpegX general discussionReplies: 7Last Post: 17th Oct 2008, 07:13 -
VIDEO_TS to DivX w/ ffmpegx
By motherwell in forum MacReplies: 2Last Post: 7th Apr 2008, 15:10 -
DivX to DVD with FFMpegX - result jerky
By akulier in forum ffmpegX general discussionReplies: 5Last Post: 19th Feb 2008, 16:40 -
ffmpegX 0.0.9 Video_TS to DivX
By stcowboy in forum ffmpegX general discussionReplies: 10Last Post: 29th Dec 2007, 02:11
