  1. Hey fellows
    yes, before you ask: I'm a newbie
    I ripped without troubles from DVDs, but now I wanted to move on to VHS and simply fail
    I use AVI_IO, play the tape, have sound everything is fine. Even set the preference "Capture sound", but after checking the file I don't have sound *sigh*
    I'm lost.....do you know what's the trouble is???
    thx
    greets
    Jayzee
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Check in control panel multimedia options, see if the record funtion is checked/muted.
    How are you inputting the sound?
    Is it via your capture card or soundcard?
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
    May 2003
    Phoenix, AZ
    Make sure in the advanced settings of your sound control panel that line in is checked as the recording source instead of microphone. That seems to be a common problem when people make their first captures.
    Howard
  4. Lost Will Hay's Avatar
    Oct 2002
    Good advice, sounds familiar though
    Will
  5. Most cature cards dont capture the audio they leave that to the soundcard. So you usually have an audio lead going from your cap card to the line in on your soundcard. Is this connected correctly.
  6. Originally Posted by Yirkin
    Howard
    YES!!!! That was it! I love your for that
    thx a bunch for your help guys
