This topic was on copying playstation dvd'sOriginally Posted by Sammer7686
If you want to copy a DVD movie its a little more involved (unless your dvd is under 4.7 gigs naturally)
Most are not, thats why the COPY method in toast doesnt work, because although it will make a .toast it will be 7 or 8 gigs, and how to do you burn that?
Instead, use DVDBackup 1.3 to copy the information to your HD.
THen use DVD2ONE to compile this information into 4.4gigs
then you burn it
its all spelled out in the sticky i have at the root of the mac video forum or you cna get informatoin on my website (see signature)
Likewise, you will see how to do vcd/svcd to dvd. mine is just one of the many ways. Its HEAVILY covered in the forum, so do a forum search for VCD to DVD or .mpeg to DVD and you will find LOTS of ways
enjoy
Results 31 to 41 of 41
OOppps! Sorry I thought you meant copying games not movies
Galactica has a good post about dvd2oneX here
https://www.videohelp.com/forum/viewtopic.php?t=156359
Good combo to use
dvdbackup (puts decrypted movie on harddrive)
dvdonex (shrinks it to fit on one dvd)
Toast (For burning)
Just reread Galactica post he already said all this stuff -
If i use the to programs listed below (dvdbackup and dvdonex I can rip a dvd and be able to play it on my ps2 without a modchip, is that correct?
its getting confusing. Origionally it was Games PS2
then someone asked if the PS2 game method works for dvd's
i should have split it when i had the chance. Oh well. -
Yes with this info you can copy a dvd movie and play it on your ps2 without any chip or trickOriginally Posted by Sammer7686
if you want to copy a game you have to follow the other instructions and you will need a boot disk with a swap method or a chip to play games -
Also i forgot to ask one more question. If the dvd is over 4.53gbs, will these programs allow me to make a dvd 9 into a dvd5 and play it on my ps2? thanks for everyones help.
Yes. Links and more info are on my website. see my signatureOriginally Posted by Sammer7686
Is the quality from dvd 9 to dvd5 a lot different? Or should i really be getting a 4.3 gb dvd-r or using two discs?
Do i need both dvdbackup and osex? Cause i downloaded them both onto my desktop and windows cant find a program to run them with. I understand they're sit files what program do i need to open those types of files? Windows doesnt know what program created it i'm using xp? thanks.
Originally Posted by galactica -
DUDE! You are in the WRONG FORUM! This is MAC VIDEO. NOT Window's VIDEO.Originally Posted by Sammer7686
these are OSX applications. The wont run on Windows.
Windows apps can run on a mac (with virtual pc) but mac apps cant run on windows.
Wonder on over to the Windows Newbie's forum, and ask what is the program to use to back up and decrypt your dvd's to your HD.
DVD2ONE is both windows and mac, so as long as you get the windows app it will work.
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 17:57 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 03:43 -
Playstation 2 plays games & DVD-Rs, but craps out on bought DVDs
By JustPlainDon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th May 2008, 18:58 -
1080i on PlayStation 3 using ffmpegx
By cpeel2300 in forum ffmpegX general discussionReplies: 0Last Post: 19th Dec 2007, 04:09 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 22:57
