I know this is a video forum, but hopefully since it's a Mac section someone can help. I can backup my DVDs just fine and was wondering if anyone knows how to backup Playstation/Xbox games. Is it anything like backing up DVDs? I haven't found anything that explains how to backup games from either platform using a Mac. Can anyone help?
Results 1 to 30 of 41
Per the great PS2DADDY
"Caution: making dvd-rips for the ps2 is not for the faint at heart and you also can do this in a pc only environment right now cant be done directly on a mac
You have to downsample either the video or audio or leave some video or audio out.
You need special tools to edit the files and replace them in the right order and add dummy files on some games its too much hassle I think but to each his own. Most of the times it is cut scene videos that are deleted and dummy files erased
Then if you dont have good no swap modchip like the messiah 2 or DMS3 (tons of others out there these are just some of the best) then you cant play the games. No solder mod or knife trick wont work on a lot of these
Unless you patch them.
The patches can be found a few places on the internet
The reason no solder mod wont play these games are that there are table of content issues and depending on the boot disk you cant play certain dvd-rs unless you have other disks with means at least 4 swaps vefore you can play a game)
For around $200 (a good price for a reliable dvd burner) you can make a DVD backup in less than 45 minutes versus the weeks of learning how to make dvd-rips and the hours and days that you will spend even after you have the process down pat
Also now people are making DVD-9 Rips
They split it up onto 2 dvd-rs or they downsample or leave out video or audio to make it DVD 5 DVD-R" -
He's trying to get them to dvd.
Which is doable on PC, but not on mac at the moment -
Oh... then its super simple
1) Put in PS 2 disc
2) Hit Copy in Toast
3) Place in Blank DVD-R (or cd if it is a cd game)
4) burn
of course you need a mod chip or a Flip-top (swap trick). there is no ps2 game i have ever heard of that needs downsampling or any "trick". -
I have copied PS2 games on my ibook with a firewire dvr-104. Use Disc Copy to make an image and then burn the image. It works every time granted that you have media that the ps2 will read well.
P.S. Galactica was talking about DVD rips for ps2 games, which is when you try to fit a dvd original to a cd-r. If you have a dvd burner and a good modchip, then you dont even have to mess with that. Dvd ripping relates back to the early days of ps2 modding, when some of the chips wouldn't play dvd-r's. All the good chips support dvd-r's. It has to do with the TOC that the chip tricks the ps2 with. -
Yes, I can confirm that fab98's method works swell. Just put Toast in Copy mode, with the ps2 game in the dvd drive, and if you only have a single DVD drive, select 'Save as Disc Image' in the 'File' menu. Then, when it's done, put Toast in 'Disc Image' mode in the 'Other' section, drag the .toast image over Toast's window, and record to a new DVD-R. If you have multiple dvd drives, put the ps2 game in the DVD-ROM drive, and a blank in the DVD-RW drive, and just use the Copy function from one DVD to another. If you want to shrink the games to fit on CD-R, here are some resources, though you will need a Windows PC, or VirtualPC:
http://www.ps2rippininfo.btinternet.co.uk/index1.htmI like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systčmes, le cas d'application excepté." -
Yeah, rips are no fun to do the are a "booger bear" (I probably typed too much about those already)
Sorry for all my long posts I try to be pretty thorough
but dvd to dvd-r is very easy
Fab98 gave a great explanation
You stick it in and hit copy pretty much
Note: I would say about 30% of PS2 games are CD and 70% DVD
Also note the 98% of any new game that comes out will be on DVD
Here is a complete guide for those that sill might have questions that I typed up for anyone that wants to see
For PS2
For those that need help with a mac
You need to use Toast Titanium 5.01 or higher
PS2 CD-R's
Open toast
If you just have a CD-RW and want to save it to your drive first
1. Select image copy (third option from the left at the top of the toast window)
2. insert CD game
3. Select "Save as image " under the file menu
4. Double Click on the image then Record image
(note you must have enough space on your hard drive to do this)
or
If you just have a CD-RW and want to just burn it
2. insert CD game
3. Click on record
it will ask you to place in a blank CD-R When ready
If you have a CD-RW and CD-Rom drive and want to copy on the fly
2. Drag CD to window
3. Click on record
If your cds are scratched there is a differnt method lemme
know if you have problems
Try burniing at a slower speed
How to make an image using astarte
1. Insert the disk and click on the “select all button” then hit save.
2. Make sure your preferences look like my attachment I included
How to patch games
Obtain PPF-o-Matic for the mac goto http://www.psxcopyworld.com
Obtain the required patch from that same site look in the psx patches and utilities sections
1. Open the program and select the Astarte iso you just created
2. Select the patch it is the file that has .ppf on the end
3. Click on apply patch
How to burn PS Game with audio tracks
1. Open toast 5 and select the “others” file cabinet in the top of the Toast window
2. Do a right click and select “Multitrack CD-Rom XA”
3. Then click on select and pick the iso file then click on “Add” repeat for each audio file and make sure that you put them in order
4. Select Record
Without Audio Tracks
1. Just double click on your Astarte image and it will put everything in the correct format in Toast Titanium 5 and click record
How to do DVD’s
You need to use Toast Titanium 5.01 or 5.02
Open toast
If you just have a superdrive and want to save it to your drive first
2. insert DVD game
3. Save as image
4. Record image (don't use burnproof)
or
If you just have a superdrive and want to just burn it
2. insert DVD game
3. Click on record
it will ask you to place in a blank DVD-R When ready
If you have a DVD-RW and DVD-Rom drive and you want to copy on the fly
2. Drag DVD to window
3. Click on record
For X-box
I found this one and I have an x-box that I am repairing and going to start this one soon
After you get a chip and install the Evox dashboard
You have to be able to network your x-box and mac via ftp then create an xiso image then use toast to burn the image
http://www.xbox-scene.com/articles/macosx-backup.php
http://www.xbox-scene.com/ is about the most complete site for x-box stuff I have seen.
Also not all X-Box games can be copied to a dvd-5 without ripping since some are dvd-9's
The PS2 has about 5 games (2 in us and 3 others in japan) and x-box has a lot more I dont know how many exactly -
Straight dvd-r copies are easy but dvd-rips are not fun sorry that I didnt make myself clear on that on that GalacticaOriginally Posted by galactica
Not a problem. Just figured I read you say
"Caution: making dvd-rips for the ps2 is not for the faint at heart and you also can do this in a pc only environment right now cant be done directly on a mac " and assumed this was not possible on a mac.
Dont have a ps2 so im glad it can be done incase i ever get one
so to set the record, those that fit onto dvd5 will work. but the dvd9 ones cant be done on a mac?? -
PS2 DVD-Rips (defined as a dvd that had been copied onto a cd in the PS2 world)Originally Posted by galactica
I know that dvd movies that are place onto dvd-r are called rips for video guys PS2 people are kinda strange and we have to change the names of stuff just because.
Should be called PS2CD like a VCD but then people would confuse it with another PS2 CD-R normal game instead of a PS2 dvd-rip
You got it dvd-5's are just like copying cd's
You can dvd-9 ripping on a pc to make it a dvd-5 and save the files to a mac then burn it but all the programs you need to rip are on the PC though. (Virtual PC might be able to be used for the PC software and then you can swithc over to the mac side for burning never tried this to say for certain though) -
Ahhh now i see where the confusion came from.Originally Posted by ps2daddy
Thanks for setting me straight. -
I've never heard of DVD-9 games for the PS2. I've never had any issues with a game yet, going to DVD-5. Really, i can't see the need for DVD-9. Any game that needs more than 4.7GB of space is simply SICK. Cut the cinematics down! That's what hollywood is for.
But yeah, i think a lot of games are so surprisingly big because they just have an unlimited amount of music in them ( you know how much music is in GTA: Vice City? )
Anyways. Just my two cents!
Peace -
I understandOriginally Posted by kamikaze
Xenosaga and metal gear solid 2
ubtance are both dvd-9
only 2 in us so far there are 3 more in japan.
I agree but if they make the games dvd 9 then most people wont go through the trouble of trying to figure out how to copy it
they cost more money to produce so I doubt if most games will be dvd 9 in the future but only time will tell
Think of the day when Computer games will be on DVD.
It may not be too far off, if it hasnt happened already!
I know there are some that have like 4-5 cd's involved, so its only a matter of time i think. -
One good thing about computer games is that if you can make a valid iso image then you can mount them on your desktop and run them. (like a dvd movie image using toast that can be remounted)Originally Posted by galactica
So if you can get an image you can use a compression program to segment it in good size chunks (like 4-5 cds) and then recreate and remount it when every you need to use it without having to do this crazy splitting and rearranging the dvd check and file order or downsampling junk though.
Makes life a lot easier than the PS2 thank goodness
Hard drives are a wonderful thing
PS2 Hard drives dont allow you to save game iso images (as of yet and the HD is only out in Japan unless you buy a linix kit)
The x-box allows you to backup your game iso images to the internal hardrive and you can put up to a 140GB harddrive inside too!
Doable, yes. Works for all - NO! More and more of the newer games have some sort of physical awareness that requires a cd to actually be in the drive!Originally Posted by ps2daddy
I prefer to play computer games off images, because the game plays faster when read from HD than from CD.
Just got Unreal Tournament 2003 for mac, couldnt wait! installed it, imaged the 2nd disk (play disk) and mounted it!
DOH! says it nees to be in the drive physically! -
For some games they have patches to by-passs this like the f1 RacingOriginally Posted by galactica
you can find some patches at www.megagames.com if I am not mistaken
You can use a program called ppf-o-matic and click on the the patch and the image and hit "ok" -
I run across some patches from time to time alsoOriginally Posted by galactica
There must be more to it than that right? You mean, I can stick my PS2 game in my Mac with a Superdrive and using Toast, I can make a working backup just by clicking record in Toast? I would like to try it but I don't want to waste a DVDr... Did I miss something or is it really that simple? Thanks.
well, if you have only one drive that reads dvdr then you cant just click RECORD, cause it will spit out the ps2 game and then ask for blank disk.Originally Posted by kagharaht
If you have 2 drives, one able to read dvd, the other able to burn dvd:
Put ps2 game in dvd reading drive, but blank dvdr into dvd burning drive, go to COPY, choose the READ FROM DRIVE, as your dvd rom, then click burn.
If you dont have 2 drive, then go to copy, choose READ FROM DRIVE as your drive, then go to FILE SAVE AS DISK IMAGE, and save it your hd.
when done, double click on image and then put in dvdr and burn
did it for a few friends disks after getting the how to from ps2daddy and it works great! -
Its that easy just remeber that you will have to find a way to play it meaning you will need a boot disk and swap method or modchip after you have made your copy to play.Originally Posted by kagharaht
I'm sorry to sound stupid. I've done searches for swap trick..err what is that? I went to the link to download instructions and this is what I found. So how do I make AR2 disk 1. Help..
"Performing the Swap Trick is very straightforward.
Load up your AR2 disc 1 and select WITHCODES. Open the tray and insert the backup. Now what I do is press X then EJECT. There is such a small space of time between pressing X then EJECT. I suggest you play around with it to see what works best for you." -
I found more information....I think I would rather have the mod chip. Any recomendations? I hate to solder the thing....
If anyone knows any information concerning my issue please respond. I have a dvd-r/w burner and ps2 and have been burning dvds using dvd decryptor which is an excellent program. i sucessfully ripped a dvd and played it on my all my sony dvd players although it didnt work on my ps2. How can i make it work? Do i need a modchip? Also how can i rip ps2 games using this program or another program if anyone has suggestions? What format do ps2 games need to be decrypted into? i know there dvds but i mean do i need to put them in iso or ifo ect?
Originally Posted by Sammer7686
PS2s are picky about the type of media that they will read verbatim, apple, and ritek are the best for the ps2 no modchip is required.
You can burn the image that dvd decrypter make but its just a lot easier to use toast.
I will recap part of a post I have about 6 comments above this works using toast titanium
How to do DVD’s
Open toast
2. insert DVD game
3. Save as image
or
2. insert DVD game
3. Click on record
3. Click on record -
Thank you very much. So where can i download the program toast and also if i understood correctly i can play the dvds on my ps2 without a modchip, is this correct? How bout burning ps2 games is that possible? So i'm using a dvd-rw drive and usually i just insert my dvd in that drive and than save it on my hard drive. Than i would insert a dvd-r and burn it on. is that simillar to what i would do in TOAST?
You need to buy toast
you can play any movie on a dvd without a chip
like I said just make sure you copy on good media
2. insert DVD game
3. Click on record
Its that easy just remeber that you will have to find a way to play it meaning you will need a boot disk and swap method or modchip after you have made your copy to play. -
thanks, do i still want to hit image copy if i'm jusy ripping a dvd movie. Also i know this is a little different of a topic, but if i have a bunch of vcds can i put them on my dvd-r and still play them on my dvd player?
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 16:57 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 02:43 -
Playstation 2 plays games & DVD-Rs, but craps out on bought DVDs
By JustPlainDon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th May 2008, 17:58 -
1080i on PlayStation 3 using ffmpegx
By cpeel2300 in forum ffmpegX general discussionReplies: 0Last Post: 19th Dec 2007, 03:09 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 21:57
