I asked about a problem @ this page https://www.videohelp.com/forum/viewtopic.php?t=161518
But it still doesn't work, can anyone tell me what is wrong?
I have encoded both files with TMPGEnc but when I try & add them to VCDEasy I get an error msg for both files. For the trailer I get "VCD1.1/VCD2.0 requires MPEG1 files, not MPEG2 files. Then for the movie I get "1972 MB : This MPEG files is too big."
How do I convert the files to MPEG1? Why is it to big?
https://www.videohelp.com/forum/userguides/84759.php That link might help you to figure out how to put a full movie onto one vcd. Also the file size that you listed is too large to create a svcd. You can encode to where the projects output size is right around 800mb because when you load up the converted file into Nero, it will compress to a smaller size and fit on a standard 80min/700mb cd-r. Also under the system tab in MPEG Settings in TMPGenc should be selected to MPEG2 Super VideoCD.
https://www.videohelp.com/tmpgencsvcd.htm
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
