Whats the easiest way to pull a snippet of sound from a vcd?
For instance, someone on a movie says something funny and i want to pull what he says off and save as a wav or mp3 or whatever
Hi,
"Easiest" way to do that is open the MPG/DAT file in TMPGenc and use the MPEG tools to cut out the part which you want. (Including video) now use the De-Muxer option to split video and audio and Voilá you have a 224Kbps MP2 file with the audio you want. You can then offcourse edit this in you favorite Audio editor and/or convert it to a different format (Wav, MP3, WMA, etc.)
Greetz,
pSyChO dAd
_________________
The difference between genius and insanity is only measured by success !
<font size=-1>[ This Message was edited by: Psycho_Dad_Rules on 2001-09-26 23:13:52 ]</font> -
How to extract I-Frame from Mpeg-4?
By ahrouhi in forum ProgrammingReplies: 7Last Post: 23rd Jan 2011, 18:56 -
How extract frames in MPEG-4
By ahrouhi in forum EditingReplies: 1Last Post: 1st Nov 2010, 01:27 -
Compare Audio Files - Extract Common Sound
By ContactGT in forum AudioReplies: 8Last Post: 28th Aug 2009, 13:36 -
How to extract video MPEG-2 from DVD?
By fvisagie in forum DVD RippingReplies: 2Last Post: 6th Oct 2008, 10:53 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
