I have gone through the past topics and cannot find any info on what I thought would be a common question.
How do you convert SVCD to VCD?
Any info would be greatly appreciated!![]()
Not to get into too much detail, the way i would do it:
Use the VCD Rip tool that comes with VCDImager (see tools) to extract the MPEG files from the SVCD.
Use TMPGEnc to convert the MPEG files from SVCD to VCD format.
Re-burn as a VCD.
Another thing you can do...
Install MPEG2 codec, copy MPEG2 file and shove it into TMPEG... (Should work)
I work in this mannor...
Magnus Jensen
A.K.A Geezus
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
