  1. Hello, I converted a DVD from PAL to NTSC using TMPGEnc (I am using: “3:2 Pulldown when play back” and “Do not frame rate conversion”, "interlace", "field A"); the problem is that when I play the NTSC DVD at some point the entire screen start to shake, especially when there are fast motions. I know that when I am too short in bitrate the video start to show small square blocks all over the screen, however this is NOT the case (I have used 6000 bitrate – more than enough for a 90 minutes movie). When there is no much motion in the movie then seems to play correctly. Does anyone know why this is happening and how to solve this problem?
    Thank you a million.
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Hello
    Take a look at this THREAD which is here on DVDRHELP
    https://www.videohelp.com/forum/viewtopic.php?t=167988&highlight=
    This should help you out
    - John "FulciLives" Coleman
  3. Member DJRumpy's Avatar
    Dallas, Texas
    It sounds like your field order is wrong. Although most DVD's are top field (A) first, yours may not be. Try reversing the setting, and encode a small clip on one of the scenes where you noticed this 'jump' to see if it resolves the problem.
    Impossible to see the future is. The Dark Side clouds everything...
  4. I did try field B but it's still the same crap
    What else can I try?????
  5. Member DJRumpy's Avatar
    Dallas, Texas
    You've verified that this 'shake' is not in your source files?
    Can you describe it in more detail? Have you looked at it on a frame by frame basis to see exactly what this shake is?
  6. I look at the original DVD in my PC ad it appear that original DVD does the same thing therefore it has nothing to do with my conversion. It is kind strange since it's a original DVD from an old Italian movie ( I am sure it was produced from VHS) .... I guess they did a very lousy job!
  7. Member DJRumpy's Avatar
    Dallas, Texas
    Lessons learned
    I've been bitten by the same thing before. When in doubt, always verify your source doesn't have the problem. You'd be suprised at some of the garbage put out onto DVD. Most people here could do a better job 8)
