  1. I am trying to burn a 68 minute xvcd onto a 80 minute cdr. The file is 750 MB. Nero 5.5.4.0 shows the length to be 85 minutes and tells me the cdr is not big enough to burn. I thought that I've burnt this large of file on previous versions of Nero.
    Should this not work?
    TIA
    leetkd
  2. It might say it is 85 minutes because it is a xvcd and the bitrate is probably higher then what you have done before. If the bitrate is higher then it of course takes more space. You could try to overburn but 5 minutes overburn is alittle much but i have done it a couple times succesfully.
