i have downloaded a full length movie in Avi format when i try to burn it to dvd+r disc it tells me that the file is over by almost 3 gigs I am using a phillips dvd+r writer and Sonic MyDVd software supported on XP can anyone please point me in the right direction?
yep, encode to DVD compliant mpeg2 using something other than MyDvd. Then also use a different authoring program. The problem is MyDvd converts all audio to uncompressed PCM which takes up LOADS of disc space, leaving much less for the video. Look to the convert and authoring guides for help.
Isnt VCD obsolete?
By omega_weapon in forum Authoring (VCD/SVCD)Replies: 63Last Post: 18th Aug 2013, 09:11 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
the movie isnt playing with consistency
By timmi in forum Software PlayingReplies: 1Last Post: 11th Jan 2009, 08:16 -
Interactive Photo CD which ISNT a slideshow?
By HBAndrew in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 21:25 -
Disc image = twice as large??
By Try4ce in forum Authoring (DVD)Replies: 4Last Post: 17th May 2007, 11:27
