I have heard of people capturing @ 480x480 and not dropping frames I cant do that without dropping 40 in 3 sec with pretty much any codec beside huffyuv, but I dont want to use that I dont have enough hard drive to capture that much video bandwith. does anyone have any suggestions.
win98
900mhz tbird
256pc133
20g wd
wintv go
im using virtualdub and i have tried pretty much every codec I can find.
there is pretty much the core of my system Im gonna bump it up from 900 to 1000+ and see if that helps. but if anybody has any suggestions let me know.
<font size=-1>[ This Message was edited by: shochan on 2001-09-27 07:11:56 ]</font>
<font size=-1>[ This Message was edited by: Shochan on 2001-09-27 13:51:14 ]</font>
It's not your processor, it's more than likely your harddrive or conflicting IRQs on your MB. Is your harddrive a 7200RPM drive ATA100, with DMA set? it needs to be. You can use the simple testing mode that comes with Virtualdub to see if your drive can keep up with the capture. Good Luck!
Onyx
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 09:41 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
