Hi,
I copied my VCD .dat files onto my computer for storage. But when I burned the .dat from my computer onto a CD-RW, my VCD player won't play the disc??? It said that it is not the correct format.
I need help because I have thrown away some of the original VCDs.
Many Thanks,
Casey
How did you burn the .dat? You must burn as VCD, www.dvdrhelp.com/vcdeasyhowto
Thanks Baldrick! I am sure your "cunning plan" will help.
Regards,
Casey
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 11:43 -
Nero Vision to convert .dat file to DVD disc - AUDIO ISSUE
By tlj in forum Video ConversionReplies: 1Last Post: 31st Dec 2007, 17:32 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
