4X writing is failing in Nero and giving me a "reset occured" error, while 2X writing succeeds.
I'm using proven media -- RITEKG04 and my drive is flashed with Herrie's custom 1f05 firmware.
Help! I'm almost second guessing my decision for the NEC.. I'm thinking I should've gone for the Pioneer A06 or Sony.
RG -
Originally Posted by RAAGAAman
Not all RITEKG04 are the same. That's a fact. How can you tell the difference? Well if one pack burns at 2X and the other at 4X then you know they're the same but different. I'll stick with TDK 4X DVD+R and always burn at 4X unlike RITEK.
.NET Security Updates Fail
By bevills1 in forum ComputerReplies: 3Last Post: 26th Jul 2010, 22:53 -
2nd pass encode fail
By john920 in forum Blu-ray RippingReplies: 19Last Post: 18th Mar 2010, 06:58 -
DV50 to WMV3/9 encoding = fail
By Hazarath in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2010, 16:03 -
Extra High Grade fail
By Abas-Avara in forum Capturing and VCRReplies: 2Last Post: 1st Oct 2009, 14:56 -
Current HD standard is a FAIL
By simps in forum Newbie / General discussionsReplies: 78Last Post: 20th May 2009, 05:08
