Anyone have tried the new instant copy patch 7/7/2003?The resizing problem is finally solved?
i Have just Bought instant copy & downloaded the 'patch' straight away
It never gets it right on 4.31...
It can be any where from 4.20 to 4.35 well when i've backed up any way.
Whats it like with out the patch? -
Having used IC since its inception, I consider that excellent. But, that's not the 'sizing problem' you've heard about. Its the fact that on very widescreen (2.35:1) movies, it will be about 75% of 4.31GB, because the onscreen image size is about that much smaller. Regardless of what you may read, there is nothing you can, or should, do about it. The picture quality is not affected because the ratio of pixels to image size will be the same.It never gets it right on 4.31...
LTA
VHS to pc patch cable
By Dr.Gee in forum Newbie / General discussionsReplies: 11Last Post: 7th Apr 2011, 08:43 -
Create DVD Audio Patch?
By Spawn1985 in forum Authoring (DVD)Replies: 23Last Post: 4th May 2010, 00:25 -
ffmpeg Patch - Compile Request
By Ruler2112 in forum Video ConversionReplies: 5Last Post: 14th Oct 2009, 02:39 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 06:45 -
ProjectX - possible to patch?
By netmask56 in forum DVB / IPTVReplies: 1Last Post: 21st May 2007, 01:18
