I am using CCE Basic to encode my DV footage. If I use CBR I can choose "System Stream" I end up with a file that I can put right int DVD Movie Factory and burn to DVD. If I pick VBR my only choice is "Elementary Stream". How do I get the files produced here onto a DVD?
Most authoring packages will import both a system stream (MPG), or elementary streams (M2V - Video and MPA - Audio).
Worse case, if your authoring software won't import elementary streams, then you can multiplex them in TMPGenc using FILE | MPEG TOOLS.
If your package doesn't accept elementary streams, I'd suggest you get another package
Impossible to see the future is. The Dark Side clouds everything...
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23 -
Basic Conversion ?
By Dash1 in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2008, 11:09 -
AVI->MPEG2 (CCE Basic) encoding results in incorrect video length in pla
By binister in forum Video ConversionReplies: 8Last Post: 26th Feb 2008, 17:29 -
Basic requirement
By namya in forum Off topicReplies: 5Last Post: 3rd Aug 2007, 14:17
