Hey!
Trying to convert an AVI to a DVD....there's an option in FFMPEGX that allows you to create a VIDEO_TS.
Thing is, i want this movie to have a few chapters. Not really specific as to WHEN the markers are, just as long as there are a few spread out, so you can skip along the movie to get where you want.
Because FFMPEGX is turning my AVI directly into a VIDEO_TS folder, i've gotta be able to set chapters within that program, right?
Does anyone know how to do this?
Thnx
-kami
Moving your topic to ffmpegx forum, since its ffmpegx related.
If memory serves me correctly you can't set chapters with ffmpegXOriginally Posted by kamikaze
but you can make the video and audio streams with it and let Sizzle
do the rest (tab "Other" check "Use custom chapter times (separated by
commas") and enter the desired values.
5 min. chapters should look like this:
0:00:00.00,0:05:00.00,0:10:00.00,0:15:00.00,......
correct. To say FFMPEGX makes video_ts folders must mean it can make chapters isnt true.
it will make the folder from your source file (which usually is some form of .mpeg that is whole (lacking chapters)
like ykz said, there are other programs that can do this for you.
ffmpegX
By rideaugrrl in forum ffmpegX general discussionReplies: 4Last Post: 26th Oct 2010, 11:21 -
FFMPEGx
By AnastasiaM in forum ffmpegX general discussionReplies: 1Last Post: 11th Dec 2009, 11:49 -
FFmpegX help
By Omipower in forum ffmpegX general discussionReplies: 4Last Post: 19th Aug 2008, 10:08 -
ffmpegX help
By delectabledoz in forum ffmpegX general discussionReplies: 2Last Post: 1st Aug 2008, 17:29 -
ffmpegX 0.0.9x r2 for OS X 10.5
By flo in forum ffmpegX general discussionReplies: 6Last Post: 16th Jan 2008, 10:15
