I successfully used DVDFab today for the first time in my process of backing up my discs, in this case to preserve the movie only option. I used GizmoBob's DVD9 -> DVD-5 guide located at http://www.gizmobob.com/dvd9-dvd5.htm and the process worked great (Okay, I had some media problems again, but that isn't anybody's fault except the disc itself).
Anyway, I was wondering about the ChangeGraphics. If I select one of the installed CGP packages and burn only one disc, does the "end" graphic automatically show up? The sample graphic only shows the "insert disk 2" graphics and I wondered how the program knew which endgraphic of the set of 4 to use in which instance.
Thanks in advance.
Results 1 to 1 of 1
Set default MKV size in DVDfab for a 4.37GB DVD disc?
By iamkatpeeler in forum Authoring (Blu-ray)Replies: 7Last Post: 24th Apr 2011, 09:59 -
Possible to burn a single 8gb file on a DL disc???
By moggsy in forum DVD & Blu-ray WritersReplies: 22Last Post: 11th Jan 2011, 20:09 -
Dvdfab insert disc?
By colt4523 in forum DVD RippingReplies: 0Last Post: 10th Dec 2009, 19:58 -
DVDFab Platinum - rip into single Vob?
By nrishiraj in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2008, 17:33 -
Encoding single episodes from disc with AutoGK
By stantheman1976 in forum DVD RippingReplies: 8Last Post: 20th Oct 2008, 19:12
