I used the newbie guide to the right to rip my first DVD...yep, that worked alright. However, I noticed I only got one audio file. Do I need to change the "encode streams" in settings (in SmartRipper) to get all the audio streams, or will this cause problems? Or do I need to do this somewhere else?
Liz
Actually Smartripper gives you not even one audio file.
You have the .vob files, that contain all audio tracks. Extract the audio track you want or two or all, as you like, with a audio decoder. DVD2AVI has an audio decoder, but you can not use dvd2avi for audio separately. If you want to extract more than one audio track, I recommend vob2audio. -
DVD2AVI does allow you to select the track you want to decode. Just select a different track, and save the project under some other name. (or use some other software like VOB2AUDIO).
question about ripping dvds
By angryassdrummer in forum DVD RippingReplies: 20Last Post: 22nd Dec 2011, 22:54 -
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 14:56 -
Question about ripping blu ray?
By HIimHISH in forum Blu-ray RippingReplies: 1Last Post: 21st Apr 2011, 16:21 -
Question about Anydvd and bluray ripping...
By AndyD in forum Blu-ray RippingReplies: 0Last Post: 13th Mar 2010, 19:05 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 22:09
