I have tried in vain to get a decent DV capture via firewire with Adobe Premier 6.5. Tried VirtualDub but it wont work for DV.
Anyone have a program they can recommend?
Here's one I use:
ScenalyserLive. It should be in the tools section under capture. Preview, timer, audio preview. I've never had a problem with it yet. Not free, but worth the relatively low price.
G -
J & G
You don't 'capture' with DV/firewire , you 'transfer' the data.
If you are not getting decent DV capture then either the source is crappy or you may have premiere set incorrectly. From memory, by default Premiere uses the MS DV codec. Try another DV codec.
Other DV 'capture' tools
http://www.slashcam.com/directory/Software_Tools-Capturing.html#k819
All DV capturing program will give you the same quality. You can try freeware programs such as DVapp or DVIO.
Best Capture Program???
By Dom_Sisko in forum Capturing and VCRReplies: 2Last Post: 11th May 2008, 22:49 -
Best Webcam Capture Program
By Rowan88 in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 09:02 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20 -
Screen Capture Program ?
By Endemoniada in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 15:45
