What cheap media works well with the Pioneer A06? I don't care about the speed as long as it is 2x or higher. Just asking because I wasted $150
on media for my NEC 1300a that didn't work. I Don't want to make the same mistake again.
To be honest, id recommend a High speed sample pack like you get from meritline.com or supermediastore.com
Meritline Pack
Meritline™ 4.7GB DVD-R 4X General (2 Discs) 102-002
Accu™ 4.7GB DVD-R 4X General (2 Discs) 102-096
DVDPro 4.7GB DVD-R 4X General (2 Discs) 102-074
Optodisc™ 4.7GB DVD-R 4X General (2 Discs) 102-091
BeAll™ 4.7GB DVD-R 4X General (2 Discs) 102-092
Supermedia Pack
5pcs DVD Pro 1X-4X DVD-R media.
2pcs Optodisc Gold Writable Surface DVD-R media.
2pcs Ritek 1-4X DVD Media.
Personally, id recommend both, the only problem is Supermedia store gives you 5 of the dvd pro disks (some people like these, others do not)
Its your call. 19.99 doesnt hurt much.
This is what I did when choosing generic media. I actually like the DVD Pro better (but they have changed the pack since I tried it, Optodisc Gold Writable Surface DVD-R and Ritek 1-4X DVD Media was not offred when i tested (these are supposed to be decent).
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 06:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
