This is the problem that I am having. I am following the directions on how to use dvd2svd. I then go to rip and convert. After converting the files, I get in the log menu:
"I/O error 103 The operation completed successfully"
When I go to the file that I saved everything in, all I see is one VTS_01_0
ifo file about 44kb in size.
What am I doing wrong.
All I want to do is convert is convert a dvd to a cd
Please help
Try updating version,,,also you have to have an encoder as such ie(tmpeg_cce),,,,,also make sure in the Misc _set default folder to a folder that everything can be stored in,,,I think that it maybe that you dont have the ASPI layer installed,,,,can get from dvd2svcd.org(follow instructions)
set bitrate cd size to 800,,,,AND ALSO IN DVDRIP_TICK ACTIVATE DVD RIPPING_USE V-STRIP DONT USE INTERNAL RIPPER,,,,v-strip is better than smart ripper,,,,
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
