    Canada
    Hey!
    Just wondering. You know how the max size of any VOB is 1024 MB? Does that mean I have to encode my movie in chunks, or can I just do the whole thing...and then will whatever program I use to turn that movie into a full working VIDEO_TS automatically split the movie into multiple VOBs?
    It just seems strange that I'd have to split the encoding task up to fit 1024 MB chunks.
    TIA
    -kami
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    You can do both actually.
    If you want to make them in chunks to 1024 .vob's thats fine
    Or if you want FFMPEGX or whatever program you are using to make the .vob's split them properly you can do that also (assuming you have started with the entire movie as your source, and not just part of it like you would if you want ot make them in chunks)
    Whatever way you find the easiest do that.
