when i encode a film with main concept encoder and the avi is in 16:9 widscreen it always encodes it to 4:9 screen evenc after ive changed the settings to 16:9 in the advanced settings does any one no why this?
Had same problem with Ulead VS 6.0 and I was told by Ulead Tech. support the Ulead VS 6.0 does not support 16:9 where as Ulead VS 7.0, which I haven't tried yet. Your's might be the same case. Haven't really found much info. on this issue neither here nor anywhere else on the we. Pls. post you solution, if you find one.
Thanks. -
What are you encoding for? A DVD? A VCD?
VCD does not support anamorphic display (letterboxing a 16:9 movie). You need to manually letterbox it yourself. The current version of Mainconcept encoder doesn't do that but the new one expected in September will be able to resize.
If on the other hand you are targeting for a DVD, then there is no problem with Mainconcept. If you select a 16:9 flag the file will have it. Actually it's just a flag. You can verify it's existence with Restream
If your authoring program supports 16:9 authoring you will get a proper aspect. If not, then it will show as stretched 4:3.The more I learn, the more I come to realize how little it is I know. -
Try changing the MPEG type from "DVD" to "MPEG 2" - I had a problem with it not letting me encode film frame rate (only 29.976).
It may be limiting you to 4:3 for similar reasons... -
yeah it tis dvd that im coverting, a friend off mine has the same problem no matter wot we try the end result is always the same 4:3
and the aruthering progrem i use is ulead dvd movie factory 2 does any one no if this surrports 16:9
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
