sup fellas... got a little problem. I work on a laptop and it has 2 PCMCIA slots. One of them is occupied by an ethernet card, and I recently bought a USB 2.0 hard drive. Right now I'm using the HD through the USB 1.1, I want to upgrade to 2.0 but I need to get an extra PCMCIA card for it. That's where the problem lies... The PCMCIA slots are piled on top of eachother. My ethernet card is kind of bulky on the end, so it covers the second PCMCIA slot. So I can't fit another card in there! Another problem is, most all of the PCMCIA USB 2.0 adapter cards are just as big and wont fit in! what do I do??? I really need usb 2.0 cause usb 1.1 is helllla slooooow and it takes over an hour to extract a 1.5gb file! (yiiiiiiiikes). Help would be appreciated. Thanks
Results 1 to 1 of 1
help me to choose PCMCIA capture card
By byair74 in forum Capturing and VCRReplies: 2Last Post: 5th Jan 2012, 08:45 -
External 3D BD player for notebooks
By winter snake in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Nov 2011, 15:23 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 06:50 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Linux Notebooks: Why aren't they cheaper than Windows notebooks?
By Nitemare in forum LinuxReplies: 5Last Post: 25th Jun 2008, 15:10
