Results 1 to 10 of 10
  1. Best buy has Imations 40% off this week
    got a 50 pack for 60 bucks of -r's
  2. Member zzyzzx's Avatar
    Baltimore, MD USA
    Yeah, but do you really want crappy made in Taiwan media?
    May 2003
    Hell
    I had a really bad experience with Imation CD-R media about 8-9 months ago. I burned some of the disks and the recordable dye layer was adhered to the label material. Well, the sh!t separated from the plastic disc and with it went my data.
    I took pictures of it and sent them to Imation. They asked that I send the the media and they'd replace it. I declined (replace crap with crap?) and stopped using their products.
    Of course, YMMV I suppose.
    1010011010
  4. Yeah, but do you really want crappy made in Taiwan media?
    Whats wrong with Taiwanese media? Soon almost all DVDRs will be made in Taiwan, just like most CDRs are made in taiwan.
    Do they really have +/-dvdr's
  6. Member zzyzzx's Avatar
    Baltimore, MD USA
    Made in Taiwan CD-R's (i.e. - CMC, etc.) are typically low quality CD-R's that are usually OK out of the box but a year or two later don't work.
    I'm assuming that their DVD-R's are as bad as their CD-R's.
    You can still buy made in Japan Tayio Yuden CD-R's at reasonable prices, just look for the Fuji, and occasional Memorex or Sony spindles that say they are made in Japan.
    Maxell's and Sony's were both good CD-R's until they started repackaging cheap made in Taiwan CD-R's.
  7. Bought them, tried them.. took them back.
    Wouldn't burn a reliable disc on my cendyne dvd+r.
    Oct 2002
    INdiana
    I never had any problems with Imation cdr. Thats what i used to use when backing up all my PSX games years ago. They still work on my PS2. I have never tried the dvd-r. I also stuck with Sony, Ritek or Verbatim. I noticed they sell SOny and Memorex(sux) at Walmart.
  9. I had never had any problems with Imation CD-Rs either.. thats why I bought them so readily.. but the DVD+Rs just weren't good for me and my trusty cendyne.
