I was told that if you capture video at higher resolution than your source, the picture will become blur a bit and not that sharp anymore. Then they told me that capturing at what they broadcast is the best. In your opinion..which is better?.. capturing at higher resolution or same resolution as your provider provides. (I wish to capture at 720x576, and I know my provider broadcasts 528x576). Please decide which resolution is the best to capture? Thank you in advance....
Don't know if it is better, but I always try to capture at the resolution I will be using for the final encoding.
For example, If I am capturing from a source that is 352x480 and my final output is 720x480, I will capture at 720x480.
It is somewhat cleaner for the analog circuitry in the camera or capture card to handle differing resolutions than it is to adjust it later in software.
Just my opinion, I am sure others have differing opinions
Just what is this reality thing anyway?
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Playing 1080p video on a higher res monitor
By Long Hot Summer in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 05:25 -
Does it make sense to use higher bitrate than source AVCHD?
By cheerful in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Dec 2010, 04:13 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 08:10 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38
