I've been playing around with making VCD's, and having some fun. Reading lots of guides, and know enough to know I don't know what I'm doing yet
If I've got an avi in PAL format, should I be reconverting it to NTSC during encoding (TMPGenc), or should I just encode it in the same format. I've been converting to NTSC, since that's what I use. I've also been having a hellofa time getting 83'ish minute avi's to encode to 79 minutes using the various bitrate calcs, and I'm wondering if this has anything to do with it? Should I just leave it as PAL, and let the player sort it out (will it?).
the player will play PAL yes. ive not seen one yet that doesn't. its just a question of whether your TV will play a PAL signal. make a disc and test it out.
Many current DVD player will play Pal or NTSC disks no problems. It's cheaper to only make one type of machine rather then two! They then convert the output to what format is used in your area or choosen in the setup screen.Which is good since almost no TV's sold in North America will play Pal.
I made one to test it and it appears to work fine. Not converting the format during encoding also seems to be helping alot when making the files come out the right size.
Connecting PC To HDTV Newb Question
By pr0bation in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2010, 18:29 -
Sorry for the NEWB question. Edit DVD.
By MPTech in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2010, 18:50 -
New newb with old question
By Madzir55 in forum RestorationReplies: 4Last Post: 17th Jan 2010, 12:05 -
Newb FCE Question
By Jralph in forum MacReplies: 3Last Post: 17th Apr 2009, 10:56 -
Newb Capture Help/Question
By sheblom in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 11:42
