    ireland
    Can someone let me know why my Soundblaster Audigy Platinum sound card will not read drive E:, ie it wont play any CD's/DVD's ?????
    Help Please
    Thanx
    Cathy 8)
    Feb 2002
    Clearwater, FL USA
    Is the audio cable from the back of the drive plugged into the sound card?
    Evil flourishes when good men do nothing.
    ireland
    Yes - It was working when we initially installed it but for some reason now it wont work ???
    Oct 2002
    The Netherlands
    Maybe the input muted??? Maybe Volume set to 0??? -> Check Mixer
    Maybe switched input to digital (only XP)??? -> check drive props...
    Else -> Duno
    'HAG
    ireland
    tanx - ill try dat !!
  6. Banned
    Feb 2003
    Columbus, Ohio
    try control panel, sound and audio device, click the place the volume icon in the task bar, click apply
    click on the speaker icon
    then u can check your volume section
    ireland
    cheers......
