Hello,
I got some avi files (at least i think they are), cant play them (i have windows mp, quicktime, winamp, divx) Ive tried using gspot and avicodec to see what they are but those fail. At a loss at what to do since if I cant tell what they are then I cant encode them. Any ideas or thoughts? Much appreciatedThanks for your time!!!
I also have vdub and rad tools but those too fail with these avi files.
There are a few avi fix progs about like Divfix. Try that, it may work.
Also is there any way you can find out what codec has been used to produce your avi? It may be you have not got the codec installed. -
I will try with DivFix ..these were files I downloaded and they were marked as avi's so Im assuming they are . Unless there is some codec I don't have. Thanks for the input
virtuldub can not open avi file?
By wuqingshi in forum EditingReplies: 6Last Post: 1st Sep 2011, 20:40 -
TmpgEnc Express can't open some AVI
By pcb in forum Video ConversionReplies: 7Last Post: 29th Jul 2011, 13:28 -
HC Encoder -How to open AVI files
By MI6 in forum Video ConversionReplies: 6Last Post: 30th Nov 2010, 14:15 -
cannot open avi file
By ione in forum Capturing and VCRReplies: 8Last Post: 14th Sep 2008, 21:02 -
Can't open AVI clips
By sndfx69 in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2007, 20:17
