I have joined 35 MPEG 2 Video clips for DVD( all of the same video/audio data rate) using either TMPG or Video studio 6. In each case the audio slowly gets out of sync. Is there as easy was to fix this. ( I have used Wavelab plus many other audio editors but the results are inconsistant.) Is there a way I can join theses with out loosing sync? After viewing the posts it seems many other have had similar problems. Surely there must be a away to fix this as everything is within syn to start with.
Audio & video out of sync
By gaboone in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2011, 21:21 -
Stargate SG-1 Season 6 & 7 A/V Sync Problems
By slider5634 in forum DVD RippingReplies: 16Last Post: 24th Jul 2009, 18:21 -
Sync problems converting Sex & The City Movie (videora)
By Putana in forum DVD RippingReplies: 0Last Post: 11th Dec 2008, 13:55 -
[?] Audio Sync & Compression Problems. Trying to start a series.
By shibbuh in forum MacReplies: 2Last Post: 26th Nov 2008, 16:26 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 01:24
