does anyone know the EXACT GOP sequence header in a DVD/VCD compliant MPEG1? DVDit wont accept in so then it wont play on a standalone. i use PWI to encode, but it still plays on standalone when i use VCDimager or whatever.
"IBBPBBPBBPBBPBBI..." is this correct?
or does my quantizer matrix need to be MPEG1 Standard. it is set at Natural Image right now.
later bater. deltaboy
used MPEG Corrector and it worked. but still, i dont want to have to do this everytime after i encode. i must be able to fix PWI...
later bater. deltaboy -
I had this same problem with some mpg files. The way I got the files to work was to use DVDx to make the mpg (mpeg 1 or mpeg 2) and then DVDit will read it fine. DVDx must create the correct GOP sequence header?
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 09:58 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)?!
By Bruxo in forum Authoring (DVD)Replies: 0Last Post: 27th Jan 2008, 21:34 -
finding GOP header by opening a file in binary mode
By VBMizio in forum ProgrammingReplies: 1Last Post: 30th Aug 2007, 06:38
