Hi, I am new to Adobe 6.0 I have been trying to transfer my video frm my SONY TRV110E to computer via 1 Firewire card through Adobe 6.0
However the video is choppy or looks watery and when I playback with Windows Media player 9.0 it is the same. Am I missing some codecs here?
Pls help
hello sir
i read your problem in using adobe premiere 6.01
i was thinking did you try out all the codec for your avi format ?
or you can alway try getting this plugins for your premiere - mpeg plugins
it works better for exporting to mpeg format than raw avi format
the other method would be export it to raw avi then re encode to mpeg format
email me if you have questions
g281274@hotmail.com -
If you are playing a DV-AVI in Media Player, you are seeing the Interlace effect of the video played on a progressive monitor. On a TV, you won't notice it. If you have PowerDVD on your PC, try playing it there. PowerDVD has a built-in Deinterlce filter for playback.
VirtualDub Capture Mod - Choppy Audio Playback?
By alinhoalisson in forum Capturing and VCRReplies: 11Last Post: 22nd Dec 2011, 13:34 -
Import/Capture Video from MiniDV - Audio is Choppy
By Guy Leatherman in forum Capturing and VCRReplies: 17Last Post: 21st Oct 2010, 12:35 -
Problem at Adobe Premier 6.0 : Extracting .MOV movie
By chineloninja in forum EditingReplies: 1Last Post: 8th Jul 2008, 19:03 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 15:24
