When burning discs, I'm often getting an error through DVDxCopy and nero that reports a "reset" error.
Nero says it's a "reset reported" error.
DVDxCopy says:
"Write operation not succesful.
Power on or bus reset error reported by DVD recorder.
Driver error code=02062900h.
The disc is not succesfully recorded."
What is going on? I am able to write some DVDs, and all those that fail get the above errors.[/b]
Results 1 to 9 of 9
I don't have an answer however I would first look in windows device manager and make sure that the NEC burner has DMA enabled. Also I would (until I had the problem figured out) disable any programs running in the background prior to doing a burn. Finally use RW media until the problem is resolved to avoid wasting media.
I should also add that the error your getting could be a hardware issue like for example memory chips not seated or even the IDE connector going into the NEC drive or motherboard not seated correctly, so maybe check that. -
I shoudl clarify that I was able to make copies yesterday using DVDxCopy Xpress.
Today not able to make any copies...
Also, the NEC ND-1300a is inside a USB 2.0 enclosure to make it external. The DVD drive is able to function properly reading data so I don't think it's a problem with the IDE connection or USB 2.0 cable to my computer. -
I have never had that warm fuzzy feeling about using any external burner CDR or DVDR.
Bet the drive works fine if installed internal.
I don't see a reason why it wouldn't work inside the USB 2.0 enclosure if it works to read all media just fine.
May have found my problem!!
http://support.microsoft.com/?id=820759
This Microsoft KB article describes a problem with USB 2.0 devices issuing a "bus reset". They have a hotfix available and it will also be distribtued as part of WinXP SP2.
Time to call MSFT support -
That drive is messed up. I had a repackaged NEC 1300a in a USB/Firewire enclosure by Cendyne. Get rid of it or sell it. Get the Pioneer A06/106 because you can get one for around $220.
Originally Posted by MCLAREN5TH
Originally Posted by bobby_t1
Samsung c500 reset ***HELP***
By Samsungc500 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Nov 2011, 18:51 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 17:45 -
How do I reset the code?
By deltarory in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 04:35 -
Magnavox mdv430 How to reset
By soluble in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 13:27 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 01:11
