I just spent a few hours ripping all my dvds with smart ripper until i found i have to use DVD Decrypter in file mode is there any way to burn these already ripped dvds or do i have to re-rip them all???
No, you don't! Many people prefer SmartRipper over DVDDecrypter anyway. If the files are in this form, rip away.I just spent a few hours ripping all my dvds with smart ripper until i found i have to use DVD Decrypter in file mode is there any way to burn these already ripped dvds or do i have to re-rip them all???
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
Otherwise, use 'Create video manager' in DVDFab, to change your file to this 'format'.
Then put into a VIDEO_TS folder, click on VIDEO_TS.IFO to test-play the file and burn away!
LTA -
mine dont have the .bub they have the .vob .ifo and they have .d2v .idx .lst (but i think those came when i tried to make my dvd into an svcd)
No sound? From what? Playing VOB files off your hard drive? A completed DVD Disk that you burnt? No sound while trying to play in your computer's DVD-Rom drive or set top DVD player or both? Please fill in the blanks.
Could it be possible that when you ripped the DVD using SmartRipper, you selected to split the Audio and Video Streams into two separate files by accident? The video usually preserves the VOB extension which a lot of cases, would lead you to believe that it's Video and Audio.
Looks like you may have to re-rip that. -
When you ripped, you inadvertantly demuxed -- split the sound away from the VOB files. That's what those extra three files were. I'm afraid the easiest thing to do now is to rerip, using the 'file' mode in either ripper. You may still have to use DVDFab, as I described above, to get a full set of files for burning.Could it be possible that when you ripped the DVD using SmartRipper, you selected to split the Audio and Video Streams into two separate files by accident? The video usually preserves the VOB extension which a lot of cases, would lead you to believe that it's Video and Audio.
BTW, you might want to experiment with DVDShrink -- my choice. It's free, and You may prefer it.
LTA
Best CD ripping
By magillagorilla in forum DVD RippingReplies: 36Last Post: 14th Sep 2015, 23:53 -
Ripping with Im Too
By rocks911 in forum Blu-ray RippingReplies: 3Last Post: 5th Oct 2011, 19:57 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
ripping help
By merkzilla in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2008, 22:38
